September 26, 2022 at 9:58 am
FAQParticipantProblem: An electrical conduction simulation in Discovery Live shows no results
Cause: The material library that was included with the 2019 R2 installer did not have electrical conduction properties defined
Solution: The material library must be replaced with an updated version.
- Close Discovery Live if it is currently open
- Navigate to
C:Usersuser nameAppDataRoamingSpaceClaimDiscoveryMaterialLibrary - Locate MaterialLibrary.xml and delete it
- Launch Discovery Live again. The new material library should be obtained automatically
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
