September 26, 2022 at 10:00 am
FAQParticipantStructural FEA simulation is often a bottleneck in early or delayed design stages. Due to multiple steps with long lead times, design exploration, what-if scenarios and multiple concepts become very slow and costly. ANSYS Discovery Live is the union of fast and easy 3D creation and editing and unmatched real-time solver technology. Structural simulation can now be used during any point of the design process to compare ideas, improve performance or reduce weight and cost.
Download and open these pre-solved examples to gain an understanding of what ANSYS can help you Discover Live.
1) Structural Deformation in a Plastic Housing
Application example of the deformation of a plastic housing with cut-outs is studied. The change in deformation under different load locations and cut-out locations/shapes can be explored. This project requires release 19.2 or newer.
2) Structural Simulation of a Clutch Housing
Application example of a structural simulation of a clutch housing and frame to understand the frame deformation under vertical load. This project requires release 19.2 or newer.
3) Tie-rod Connector Stress Simulation
Application example of a tie-rod connector simulation using parameter studies to investigate changes in geometry and changes in loading. This project requires release 19.2 or newer.
4) Structural Simulation of a Snap-Fit Buckle
Application example of a snap-fit buckle in Discovery Live utilizing face displacement as an alternative to deformation by non-linear contact. This project requires release 19.2 or newer.
5) Torsional performance of a gear housing
Application example of the structural performance of the gear housing is investigated. A simple torsional load is applied to one end of the structure and the opposing end is fixed at the bolting locations. A parameter study is also included to look at the effects of the overall length of the structure. This project requires release 19.2 or newer.
6) Structural Loading of Hip Implant
Application example of a simple loading being applied to a replacement hip. The high stress locations and overall part deformation can be visualized and measured. This project requires release 19.2 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
