September 26, 2022 at 9:59 am
Watch & LearnParticipantThis video will walk you through the vibration analysis of the Frame of a Pick-up truck. The modal analysis is done on Discovery Live to quickly check the mode shapes and then a more detailed Random Vibration analysis with Gravity Acceleration PSD input is done in Discovery AIM. A point load is also added to the Random Vibration analysis to represent the GVW loading on the Frame.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
