September 26, 2022 at 9:53 am
FAQParticipantFor Discovery Floating Licensing issue, please gather diagnostics for review as mentioned below. Please do this for your Client machine as well as for the Server machine. If they are one in the same, please have them run BOTH sets of instructions below as they will each gather distinct details needed to troubleshoot.
CLIENT:
For version 2021 R1 and later:
1. Launch ANSYS Client Licensing Setting 2021 R1 utility from windows Start menu.
2. Click Gather Diagnostic
3. Click Generate
4. The diagnostics zip file will get saved at a particular location whose path is mentioned in the panel.
5. Please email that zip file to ansys-discovery-support@ansys.com
For older versions:
1. Launch the Client ANSLIC_ADMIN Utility as the user experiencing the problem.
2. Click View Status/Diagnostic Options
3. Click Gather Diagnostic Information
4. Select Yes when prompted
5. If you would like to specify the directory of the diagnostic files, select Yes. If not, select No (there will be a pop-up window displaying the location of the diagnostic files once it’s finished gathering the files)
6. Please zip the entire diagnostic directory and email it to ansys-discovery-support@ansys.com
Please refer to this Animated Tutorial for assistance with how to obtain the diagnostics on the Client side and for license servers running Version 15 or earlier version of the ANSYS Inc. License Manager.
Gathering Client-Side Diagnostics for ANSYS
SERVER:
If your License Server is running version 16 of the ANSYS Inc. License Manager, please follow these steps for gathering the server side diagnostics.
1. Launch ANSYS License Management Center
1.1 For Windows: Click Start>All Programs>ANSYS, Inc. License Manager> ANSYS License Management Center or copy and paste this http://localhost:1084/ to any web browser
1.2 For Linux: Run the start_lmcenter script in ansys_Inc/shared_files/licensing/ directory
2. Click Gather Diagnostic Information
3. Click SAVE TO FILE, the diagnostic folder will be created in the same directory as the “Download Location” set for the web browser that is used to open ANSYS License Management Center. If the web browser displays options between save and open, please save the file.
4. Please email it to ansys-discovery-support@ansys.com
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
