Tagged: Explore-FAQ, fluids, parameter, structures, thermal
September 26, 2022 at 10:15 am
FAQParticipantPlease find below the steps to perform a Parameter Sweep Study in Discovery Explore Mode:
1. The first step starts with creating parameters. The process of creating a parameter is very simple. Use Move or Pull tool and click the parameter icon
located next to the dimension value for creating a parameter.
All the parameters created are visible under Groups panel which can be accessed from Advanced Selection option located at the bottom.
2. Once the parameters are created, a new Parameter icon appears in the Simulation Information Display (SID) menu.
3. Click on this icon to open Parameter Study panel.
4. Click “Create Design Variations” button
. This will open Design Variations Generator Panel. Select the parameter from the Parameters list. Then specify the Start value, End Value, Interval and Number as required.
5. Add additional parameters as required for the study and set its values.
6. Once the parameters are defined, click “Create Design Variations” button located at the bottom right corner. This will create Design Points table will all possible combinations of the parameters.
7. You can now click the Solve options and solve for current or all desgin points.
8. You can click the Show Chart button
to see the parameter chart for all Design Points.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
