September 26, 2022 at 9:53 am
FAQParticipantProblem: With Discovery Enterprise license, following warning message may appear:
WARNING: Licensing files currently installed are more recent than those on the installation media.
The files will not be installed and will be deselected….
Cause: The installation of Discovery Enterprise contains some newer .exe files than the license manager installation. This causes the error seen.
Recommended solution: To fix this issue, Delete or rename the existing ‘Shared FilesLicensinglicadmindocuabout.licadmin’ file, usually located within C:Program FilesAnsys Inc. Then try reinstalling the updated License Manager.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
