Legacy Products
Legacy Products
Discovery AIM tutorial – Thermal Analysis of an Electrical Wire
    • SolutionSolution
      Participant
      This example is taken from Cornell University’s ANSYS AIM Learning Modules
      In this tutorial, you will learn to :
      • Perform thermal analysis of electrical wire
      •  Determine the centerline temperature of wire
      For this demonstration, we are asked to determine the centerline temperature, Tc, and surface temperature of a bare steel wire carrying a current, I, and having a resistance, R. The surface convection coefficient between the wire and the ambient air (at temperature Ta) is h.
       width=
      Using Ohm’s Law  I R = V the voltage drop along the wire is calculated to be 0.1 volts. The resistivity is also calculated using the equation  width=, which is calculated to be  width=. We are now ready to begin the simulation.
      Download the file here
      The following video shows how to import the geometry in Discovery AIM.
      The following video shows how to define a new material for the wire and specify electrical and thermal boundary conditions.
      The following video shows how to compute the centerline temperature of wire.
      From the Ansys Mechanical APDL Verification Manual problem VM119 the calculated centerline temperature was 420.0 F (215.6 C). The percent error between these two calculations is 0.102%. In conclusion, the solvers calculation for the centerline temperature is accurate.
       width=
