September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
Consider the case of a fluid flowing past a cylinder, as illustrated above. Obtain the velocity and pressure distributions when the Reynolds number is chosen to be 20. In order to simplify the computation, the diameter of the cylinder is set to 1 m, the x component of the velocity is set to 1 m/s and the density of the fluid is set to 1 kg/m^3. Thus, the dynamic viscosity must be set to 0.05 kg/m*s in order to obtain the desired Reynolds number.
Pre-Analysis
Solution Domain
For an external flow problem like this, one needs to determine where to place the outer boundary. A square domain will be used for this simulation. The effects that the cylinder has on the flow extend far downstream. Thus, the distance to the outlet end boundary will be much larger than the distance to the inlet boundary.
Boundary Conditions
First, we will specify a velocity inlet boundary condition. We will set the left side of the outer boundary as a velocity inlet with a velocity of 1 m/s in the x direction. Next, we will use a pressure outlet boundary condition for the right side of the outer boundary with a gauge pressure of 0 Pa. Lastly, we will apply a no slip boundary condition to the cylinder wall. The aforementioned boundary conditions are illustrated below.
Geometry Creation
In this video, you will learn how to create a computational flow domain around the cylinder.
Mesh
In this tutorial, we will be using Physics-Aware Meshing. Physics-aware meshing helps automate and simplify your problem setup. With physics-aware meshing, the computational mesh is generated automatically based on the solution fidelity setting and the physics inputs.
Physics Setup
In this video, you will learn how to create a new material and assign fluid flow conditions to the model.
Results Evaluation
In this video, you will learn how to check velocity vectors, pressure change in the fluid domain and total pressure on the cylinder walls.
Validation
This tutorial will be compared to results found in the Fluent – SimCafe tutorial based on the same problem. Below is the pressure contour from the SimCafe tutorial.
This can be compared to the pressure contour calculated in the simulation. Select the pressure contour created in the results section, then change the Coloring to Banded to match the display style in the image above.
The AIM solution not only has similar maximum and minimum values for pressure, but the shapes of the pressure contours are virtually identical.
Reference
Singleton, John Matthew, Jr., and Sebastien Lachance-Barrett. “FLUENT – Steady Flow Past a Cylinder.” Dashboard. Cornell University, 8 Feb. 2014. Web. 19 July 2017.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
