Tagged: AIM tutotrial, discovery-aim, electromagnetics suite
September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Learning Goals
In this tutorial, you will learn to:
- Determine magnetic flux density and field intensity in the permanent magnet and the air gap
Problem Specification
A permanent magnet circuit consists of a highly permeable core, a permanent magnet, and an air gap. Determine the magnetic flux density and field intensity in the permanent magnet and the air gap.
Pre-Analysis
Governing Equation:
Magnetostatics is the study of magnetic fields in devices where the magnetic field is generated from DC (steady) currents and/or permanent magnets. Magnetostatics is a special case of Maxwell’s equations, which form the basis of electromagnetism.
For magnetostatics the electric field inside of a current carrying coil is completely decoupled from the magnetic field, and the following Maxwell’s equations are solved for magnetostatics –
Where ∇ denotes divergence, H is the magnetic field intensity, J is the current density and B is the magnetic flux density.
Geometry
The following video shows how to import the geometry in Discovery AIM.
Physics Setup
The following video shows how to assign materials and its properties.
Results Evaluation
The following video shows how to compute magnetic flux density.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
