September 26, 2022 at 10:00 am
Watch & LearnParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
A wing with a NACA 0012 airfoil section is supported such that one end is fixed and the other end is free. The wing has a chord of 1 meter, a span of 5 meters, and a thickness of 0.01 meters. The wing is Aluminum 6061-T6. Find the first 6 modes of vibration of the airfoil using ANSYS AIM.
Geometry
In this video, you will learn how to:
- Import the geometry in Discovery AIM
- Specify thickness of the wing surface to be 0.01m
Mesh
In this tutorial, we will be using Physics-Aware Meshing. Physics-aware meshing helps automate and simplify your problem setup. With physics-aware meshing, the computational mesh is generated automatically based on the solution fidelity setting and the physics inputs.
Physics Setup
- Change the material of the wing to a new material with the name Aluminum 6061-T6
- Add a density property of 2700 kg/m^3
- Add an Isotropic Elasticity property, with Young’s Modulus = 1e7 psi and Poisson’s ratio = 0.33
- Add a fixed support on two edges of the wing’s end
Results Evaluation
In this video you will learn how to:
- View Displacement Magnitude contours for each mode
- Look at the calculated modal frequencies
- Refine the mesh and investigate any change in modal frequencies
Verification & Validation
One of the ways we can check the validity of our analysis is by refining our mesh. If the values for our frequencies approach a limit, then we have arrived at our answer. If the values change drastically when we refine the mesh, then we need to refine the mesh further and we have not yet found an acceptable solution. We will refine the mesh by increasing the Mesh resolution, as in the Numerical Results video. The table below shows the results from the video. Since the frequencies do not change, we do not have the refine the mesh further.
Mode Number Frequency (Unrefined Mesh) Frequency (Refined Mesh) 1 4.6563 4.7554 2 24..785 25.087 3 31.701 32.087 4 37.989 38.247 5 51.152 49.506 6 59.988 56.756
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
