September 26, 2022 at 10:00 am
SolutionParticipantProblem Specification
In this tutorial, the common transition duct pictured below will be the subject of our simulation. These are commonly found in office buildings and are sometimes used to vent air into the atmosphere. For this example, the temperature at the inlet of the transition duct is 73 degrees Fahrenheit. If air travels at 33 feet/sec at the inlet, find the velocity vectors inside the transition duct and find the pressure exerted on the transition duct from the air within.
Geometry & Mesh
In this video, you will learn how to import the geometry in Discovery AIM and how to generate mesh in the computational fluid domain.
Physics Setup
In this video, you will learn how to specify fluid flow conditions.
Results Evaluation
In this video, you will learn how to evaluate velocity vectors, Total Pressure and Temperature contours in the flow domain.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
