September 26, 2022 at 10:00 am
Watch & LearnParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
A wing with a NACA 0012 airfoil section has a chord of 1 meter, a span of 1 meter, and a thickness of 0.01 meter. The wing is made of Aluminum 6061-T6. If air moves at 987.84 km/hour around the airfoil, find the velocity vectors of compressible flow over the airfoil.
Geometry & Mesh
In this video, you will learn how to import the geometry, perform required geometry operations in Discovery AIM and how to generate mesh in the computational fluid domain.
Physics Setup
In this video, you will learn how to specify fluid flow conditions.
Results Evaluation
In this video, you will learn how to evaluate velocity vectors, Total Pressure and Temperature contours in the flow domain.
Verification
In order to verify that the simulation is accurate, it must be compared to a study that is similar in nature. We will compare the AIM results with results from Stanford University’s Aerospace Design Lab. In that study, users were expected to become familiar with performing an optimal space design in a 2D space. The airfoil used was also the NACA 0012, which makes this a perfect example to compare ours to. Below is the pressure contour that was plotted as a result of the Stanford tutorial, which can be directly compared to the pressure contour found in the previous section.
References
Copeland, Sean and Economon, Thomas. “Quick Start Tutorial – SU2 – ADL Software Documentation.” Aerospace Design Lab. Stanford University, 1 July 2014. Web. 7 August 2017.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
