September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
Consider an aluminium beam that is clamped at one end, with the following dimensions.
The aluminium used for the beam has the following material properties.Using ANSYS Discovery AIM find the first six natural frequencies of the beam and the mode shapes.
Geometry
In this video, you will learn to create a cantilever beam for the modal analysis according to the dimensions specified.
Mesh
In this example, we will be using Automatic Physics-Aware Meshing. Automatic physics-aware meshing helps automate and simplify your problem setup. With automatic physics-aware meshing, the computational mesh is generated automatically based on the solution fidelity setting and the physics inputs.
Physics Setup
In this video, you will learn to assign material and modify it according to the problem specification and also assign boundary conditions for the cantilever beam.
Results
In this video, you will see how to extract the frequencies for all the modes and also determine the mode shape and contours.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
