September 26, 2022 at 10:00 am
Watch & LearnParticipantLearning Goals
In this tutorial, you will learn to determine:
- Fluid volume extraction
- Flow field within the box and maximum temperature on the components.
Problem Specification
Currently, a design for an electronics box calls for 10 electronic boards and a CPU to be enclosed. All these electronic components will generate heat of 40,682 watts per meter cube. The current design uses two fans to blow air through the box to cool the electronics. The fans blow air at a rate of 35 cubic feet per minute i.e. 57.609 inches/second. The box is expected to operate in an environment where the temperature reaches a maximum of 114 degrees Fahrenheit. The main constraint on the design is that the electronic components need to be maintained below 200 degrees Fahrenheit, otherwise the components could be damaged.
The box itself is ABS plastic, the components will be modeled as copper. This tutorial will show you how to use Discovery AIM to model this problem.
Geometry
The following video shows how to:
- import the geometry.
- open geometry editor to fill small holes and create flow volume.
Mesh
In this tutorial, we will be using Automatic Physics-Aware Meshing. Automatic physics-aware meshing helps automate and simplify your problem setup. With automatic physics-aware meshing, the computational mesh is generated automatically based on the solution fidelity setting and the physics inputs.
Physics Setup
The video below demonstrates how to specify the flow and thermal boundary conditions for the electronics box simulation.
Results Evaulation
The video below shows how to:
- Change the arrow sizing and number of symbols to 5000 under the velocity result.
- Add a temperature contour and animate the results.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
