September 26, 2022 at 10:00 am
Watch & LearnParticipantThis video demonstrates how to calculate thermal stress from a fluid-solid heat transfer solution in ANSYS AIM. The fluid-solid heat transfer and structure simulations are solved separately. Temperature data is transferred from the solved fluid-solid heat transfer simulation into the structural simulation using the physics coupling interface. For the initial setup of the simulation, see the ANSYS AIM: Fluid-Solid Heat Transfer video. ANSYS AIM provides easy simulation software for design engineering in an integrated multiphysics simulation environment.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
