September 26, 2022 at 9:59 am
Solution
Participant
fuse-structural-thermal-electromagnetics-19-0.zipApplication example of a structural-thermal-electromagnetics simulation of a fuse assembly. A 30A current is applied to the fuse which is rated for 10A. The temperature distribution through the aluminum fuse element and polyethylene body is calculated based on the resistance heating of the element. The thermally induced stresses are also calculated. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM – Scaling deformation contour results
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- How to setup a Parameter Study
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
