Tagged: AIM App Example, discovery-aim, discovery-live, structures
September 26, 2022 at 9:58 am
SolutionParticipantApplication example of a sway bar assembly including non-linear contact, hinge and spherical joints, bolt pretension and multiple load steps. This project requires release 19.2 or newer.
Also included with this example is a Discovery Live file which contains simulations evaluating the structural performance of the bracket. Loading in the Live simulation is based on joint force and moment outputs from the assembly level simulation run in AIM.
Alternative keywords: anti-roll bar, roll bar, anti-sway bar, stabilizer bar
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
