Tagged: Application Examples, discovery-aim, structures
September 26, 2022 at 10:00 am
FAQ
Participantpressure-vessel-structural-19-0.zip
Application example of a structural simulation of a pressure vessel. A pressure differential of 10 psi is applied to the steel vessel where the walls are set up as 2D surfaces. Equivalent stress and displacement are plotted in the results. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
