September 26, 2022 at 9:59 am
SolutionParticipantDuring the evaluation of contour plots, you may want to scale the deformation of model to get a better visualization of the deflection. This scaling feature is available under Results task – Settings – Graphics Control – Deformation scaling. See below image showing this option.
- The Auto scale gives you the best scaling where the true deformation cannot be easily visualized. You can use other predefined scaling factors (0.5x Auto, 2x Auto, and 5x Auto) to change the magnitude of the scaling.
- The Custom option will help you to specify a scaling factor of your choice.
- To display the true deformation of a physics region, set this option to Actual.
- To ignore the deformation, set this option to None.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
