Tagged: AIM, discovery-aim, How To, polymer-extrusion, Tutorial, tutorials
September 26, 2022 at 10:00 am
Watch & LearnParticipantIn this demonstration, you’ll learn how to set up and solve a polymer extrusion problem in ANSYS AIM. For this particular example, we’ll examine the flow of a polymer melt as it is pushed, or extruded, through a three-dimensional die. As the polymer fluid is extruded out of the die, the free surface of the extrudate is exposed and begins to deform.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
