April 12, 2023 at 8:34 am
Watch & LearnParticipantThese video tutorials will start you on your journey of learning with ANSYS Discovery AIM. Getting Started begins with a few introductions to the user interface and the primary physics simulations, structures, fluid flow, Fluid-Solid Heat Transfer, Thermal Electric Conduction, Fluid-Structure Interactions and Electromagnetic Physics. Explore more detailed simulations and check back frequently for new videos.
1) Structural Simulation: Learn the basics of how to setup, solve and visualize the results of a structural simulation.
2) Internal Fluids Simulation: Learn the basics of how to setup, solve and visualize the results of an internal fluid flow simulation.
3) Modal Simulation: Learn the basics of how to setup, solve and visualize the results of a modal simulation.
4) Thermal Simulation: Learn the basics of how to setup, solve and visualize the results of an thermal simulation.
5) Fluid-Solid Heat Transfer (CHT) Simulation: Learn the basics of how to setup, solve and visualize the results of a fluid-solid heat transfer or conjugate heat transfer simulation.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
