September 26, 2022 at 10:00 am
Watch & LearnParticipant
This video demonstrates how to set up and solve a fluid-structure interaction simulation in ANSYS AIM. The fluid and structure simulations are solved separately, and fluid force data is transferred from the solved fluid simulation into the structural simulation using the physics coupling interface.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
