September 26, 2022 at 10:00 am
SolutionParticipantDownload the file here
Application example of a fluid-solid interaction simulation of fluid through a bolted pipe connection with 90 degree elbow. The fluid forces are transferred to the pipe, and stresses in the pipe are calculated. The contact displacement between the bolted connection flanges is also calculated which for this example shows the bolted connection may leak. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
