September 26, 2022 at 10:00 am
Solution
ParticipantDownload the file here
Application example of fluid-solid heat transfer of a cold plate. This case is set up with multiple materials in a single solid thermal region. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
