Tagged: aim-faq, discovery-aim, fluid-solid-heat-transfer
September 26, 2022 at 9:58 am
Watch & LearnParticipantThis video demonstrates how to set up a conjugate heat transfer problem using multiple physics regions in ANSYS Discovery AIM 19.1. The video shows how to define the fluid flow physics region, define the thermal physics region, define the material assignments,define the boundary conditions, define the region interface, use the interface generator, generate a solution, and analyze the results.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
