September 26, 2022 at 9:59 am
SolutionParticipantFluid-Solid-Heat-Transfer-and-Structural-Simulation-of-an-Air-Cooled-Engine.zip
Application example of an air cooled engine simulation with fluid-solid heat transfer and structural coupling. A heat source is specified in the engine and convective cooling effects from the surrounding air are calculated as well as the temperature distribution through the engine. The engine temperatures are then sent to a structural simulation, where the thermally induced stresses are calculated. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
