Tagged: discovery-aim, Fluid-Solid, fluids, heat-transfer, How To, Structures AIM, Tutorial, tutorials
September 26, 2022 at 10:00 am
Watch & Learn
ParticipantThis video demonstrates how to set up a conjugate heat transfer problem using multiple physics regions in ANSYS AIM 17.0. The video shows how to define the fluid flow physics region, define the thermal physics region, define the material assignments,define the boundary conditions, define the region interface, use the interface generator, generate a solution, and analyze the results.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
