Tagged: Application Examples, discovery-aim, fluids, heat-transfer, thermal
September 26, 2022 at 9:59 am
SolutionParticipantShell Tube Heat Exchanger-Fluid Flow-19.0.wbpz.zip
Application example of a shell tube heat exchanger with baffles simulation. This is a fluid flow and thermal simulation where hot water in the shell is cooled by cold water moving through the tubes. The temperature distribution through the steel structure is also calculated. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
