Tagged: AIM App Example, Application Examples, discovery-aim, fluids
September 26, 2022 at 10:00 am
SolutionParticipantApplication example of a shell tube heat exchanger simulation. This is a fluid flow only simulation where the flow of water and air through the heat exchanger is calculated. Thermal effects are not calculated. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
