September 26, 2022 at 10:00 am
SolutionParticipantApplication example of a solenoid valve simulation with electromagnetic-thermal coupling. Heat generation from the coil based on the Fill Factor method is transferred to a thermal physics region where the temperature through the whole geometry is calculated. The force generated by the valve based on the current through the solenoid’s coil is also calculated. This project requires release 19.0 or newer.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
