Legacy Products
Legacy Products
Discovery AIM – Electromagnetic-Thermal Simulation of a Coil Inducing Eddy Currents in a Plate
    • FAQFAQ
      Participant
      eddy-current-heating-thermal-electromagnetics-19-0.zip
      Application example of a magnetic coil simulation with electromagnetic-thermal coupling. Ohmic losses in a plate are calculated based on the magnetic field of an adjacent coil. The losses are transferred to a thermal simulation where the temperature distribution through the plate is calculated. This project requires release 19.0 or newer.
