September 26, 2022 at 9:59 am
SolutionParticipantbutterfly_valve.scdoc
butterfly-valve-with-reed-flow-sensor-fluid-structure-interaction.pdf
butterfly-valve-fluid-solid-interaction-19-0.zipThis Discovery AIM how-to shows an analysis of flow through a butterfly valve with a coupled fluid-solid interaction analysis of a reed flow sensor in the pipe. Design points are used to parameterize the valve angle and the resulting mass flow rate and displacement of the reed flow sensor.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
