General
General
Discovery Sample Add-ins – Previous Versions
; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
