DesignModeler cannot be opened or closed while an NX Motion analysis is being run on the same PC. How to resolve this issue?
June 5, 2023 at 7:05 am
FAQParticipantThis behavior is observed when NX is configured in Associative Interface mode. To overcome this issue, configure NX in Reader mode.
