May 5, 2024 at 7:13 am
SolutionParticipantIn this article we will explore design scenarios using Ansys Discovery to lower the temperature of the CPUs, and thus ensure thermal safety by altering the material, altering the geometry, and altering the heat sink operating environment.
Refer the attached document and Simulation files on how to set up test cases, update design to analyze the impact of the material, geometry and heat sink operating environment on heat sink performance. We will explore these design scenarios and observe the improvements.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
