Tagged: ansys, Control Systems, Cyber physical systems, Designing Embedded Systems, Embedded Software, Embedded Systems, Embedded Systems Programming, Esterel Technologies, Model-based Systems Engineering, Safety Critical Applications, Safety Critical Software, SCADE, SCADE Project, SCADE tutorial, simplorer, Software Testing, Test Automation
June 3, 2022 at 1:43 pm
Watch & LearnParticipantUsing DC models implemented separately in ANSYS SCADE Suite and ANSYS Simplorer, ANSYS experts provide meaningful input values using the FMI (Functional Mockup Interface) standard for an interface to co-simulate elements coming from different tools. This demonstration shows how straightforward an ANSYS SCADE Suite generated controller runs in ANSYS Simplorer. It enables early prediction of the behavior of a complex system, including its software parts. The ANSYS Simplorer plant model can be enriched with more complex simulation models, including Reduced Order Models (ROMs) or co-simulation with many other 3D ANSYS tools. The software component used for the simulation will have the exact same behavior on the actual target, as it is rigorously the same application code.
- An introduction to DO-178C
- ARINC 661: the standard behind modern cockpit display systems
- Scade One – Bridging the Gap between Model-Based Design and Traditional Programming
- SCADE and STK – Satellite Attitude Control
- Scade One – An Open Model-Based Ecosystem, Ready for MBSE
- Introduction to Formal Verification and SCADE Suite Design Verifier
- Scade One – A Visual Coding Experience
- Using the SCADE Python APIs from your favorite IDE
- Efficient Development of Safe Avionics Software with DO-178C Objectives Using SCADE Suite
- An introduction to space software standards ECSS-E-ST-40 and ECSS-Q-ST-80C
