Tagged: Helix, Left-handed helix, Pitch, Revolve Helix, Right-handed helix, Taper angle
May 10, 2024 at 1:03 pm
Watch & LearnParticipantThis video demonstratres the use of Pull tool to create helix in Ansys Discovery. You need to define pitch, height and taper angle to generate the helix. We will also see an example where you can use this feature to cut helical grooves on the solid.
You can create a parametric helix using History Tracking in Ansys Discovery. Click on the button to activate History Tracking and follow the steps shown in the video above. After creating the geometry, you can click on the parameter icon to define the geometric parameters. To generate new geometry, change the parameter value and use the play button to create updated geometry.
- Surface to solid creation in SpaceClaim
- Split Face in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Working with Components
- Selecting all inner faces of a body
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Ansys Discovery for Geometry Preparation
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery – Detect Tool
