Tagged: Extract Curves, Facets, How To, pull, reverse engineering, spaceclaim, stl
September 26, 2022 at 10:00 am
Watch & LearnParticipantThis video explains how to create solid geometry from STL model of a lever. The process involves use of sphere tool to quickly recreate spherical sections and then extract blade curves and pull them to create solid geometry
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
