May 25, 2023 at 7:30 amSolutionParticipant
Please see attachment for solution. Keywords: ecad, SIwave, edb, design force
1. 2051527.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- ANSYS HFSS: Creating 3D Components
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- ANSYS SIwave: Electrothermal Analyses of a PCB – Part IV
- Importing Allegro, APD, SiP into Icepak via ODB++
- Translate MCM files for ANSYS SIwave & HFSS 3D Layout – ECAD Part V
