July 4, 2022 at 7:00 am
Watch & LearnParticipantIn this part we compare the stackups of the printed circuit board between Mentor Xpedition and ANSYS SIwave. The video clearly explains how the different material properties, the thicknesses, and other properties are translated to SIwave. Another important feature shown in the video is the process of generating data files with component values from SIwave. The values are modified and the data file is imported back to SIwave and the component values are changed accordingly to reflect the ones in the bill of materials file. Another key feature shown in the video is using an XML control file that can control the ODB properties to be read in by SIwave and their order. For instance, the file is configured to read in a property field in the ODB++ database that can straightaway translate all component values accurately while importing the ODB++ directory to SIwave.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
