CHT results in FLuent calculation show patchy temperatures at the Fluid/solid interface. What are some things that can be tried to address this?
January 25, 2023 at 7:16 am
FAQParticipantOne issue with CHT can be that the internally-calculated solid timescale is too large and causes divergence. Switching to the pseudo-transient coupled solver will allow you to set a smaller time scale for the solid and will help to keep temperatures bounded. Another remedy that may work for highly convoluted CHT surfaces is to set an alternate formulation for wall temperatures. In the text interface go to: solve/set/expert then say yes to the question: use alternate formulation for wall temperatures? [no]
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
