March 17, 2023 at 8:59 am
FAQParticipantIf you want the position of the interface on a vertical line you can: 1. Create the vertical line 2. Create a point with the method ‘Variable Maximum’, location ‘Line 1’, variable ‘Water.Conservative Volume Fraction.Gradient’ 3. Create an expression ZInterfaceLine1 = probe(Z)@Point 1 4. Create a chart of type ‘Time’ and for Chart Line choose the method ‘expression’ and set ZInterfaceLine1 in the expression box. Note that to do this, you will need to have stored the Conservative Volume Fraction Gradient in the trn files. To get the average position of the interface with time, you can: 1. Create an isosurface at the fluid volume fraction of 0.5 2. Create an expression like AverageZInterface = areaAve(Z )@Isosurface 1 3. Create a chart of type ‘Time’ and for the Chart Line choose the method ‘expression’ and set AverageZInterface in the expression box.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
