Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
September 26, 2022 at 9:53 am
FAQParticipantProblem: After installing Discovery products, following errors are observed when trying to launch the application.
Error:
ANSYS LICENSE MANAGER ERROR
No servers provided
ANSYSLI_SERVERS:
Error:
Cause:
The above errors are seen if a different licensing option is selected during installation against the license which you have.
The LICENSE MANAGER error appears if the licensing mode was selected as “Floating” during installation. Similarly, the “No Subscriptions” error appears if the licensing mode was selected as “Subscription” during installation.
Recommended Solution:
The above errors can be quickly fixed by switching the license mode. Go to Windows Start menu, ANSYS 19.2 folder and open “Discovery Licensing Mode Manager”. In this panel, select the appropriate license mode (refer below snapshot), then click Save and Exit.
Note: If the License Mode Manager is not available in Start Menu or if the panel cannot be edited to change the option, please go through below article for activating the License Manager.
Unable to find/edit License Mode Manager for changing Discovery license type
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
