General
General
Can’t see the ASCII drop down in Ansys 18.2 on the right hand top corner beside LSDYNA Post.
    • FAQFAQ
      Participant
      Yes, the ASCII data was taken out of the WB LS-DYNA GUI at V18.1. The access to the data moved to either in the Energy Summary under Solution Information; or a Result Tracker that can be inserted under the Solution Information object.
