March 17, 2023 at 8:59 am
FAQParticipantSome material models such as kinematic hardening are not supported for shell. User needs to check if such unsupported material models are used. Valid material models for shell are: Elastic von Mises Johnson Cook Piecewise JC Zerilli Armstrong Steinberg Guinan Cowper Symonds Bi-linear isotropic hardening Multi-linear isotropic hardening
