Tagged: 19.1, autodyn, Explicit:Autodyn, solver, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantGenerally GPU would improve performance of implicit solver, not much for explicit solver. For example, MAPDL takes advantage of GPU, while it would not help ANSYS Explicit Dynamics. So GPU is not implemented for ANSYS Explicit Dynamics.
