Can we perform 2d FSI analysis using lagrange and euler solver in Explicit Dynamics using ANSYS Mechanical Enterprise License?
March 17, 2023 at 8:59 amFAQParticipant
No, we can not do it in the standard Explicit Dynamics. We will need AUTODYN module which requires autodyn 3d licence to run.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
