Tagged: 19, fluent, fluid-dynamics, Modeling/Setup Advice, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantFluent’s built-in Newman P2D model can be used in a battery pack simulation just like any other submodel. The submodel can be called per computational cell (if you do not use cell clustering), but it will be costly. Usually cell clustering is needed to speed up the simulation. Note that the Newman P2D submodel is designed to model a small section of a pair of electrodes and detail the sub-electrode level of a battery. As such, extending it to an entire pack can be very costly and is not usually practical because of the length and time scale discrepancies.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
