March 17, 2023 at 8:59 am
FAQ
ParticipantYes, they can be included. The documentation implies that it is not possible to include material dependent properties in a modal analysis, because temperature is not an allowable load in a modal analysis. However, the temperature-dependent properties are still evaluated at the appropriate temperature before performing the analysis.
