June 6, 2022 at 9:58 am
FAQParticipantNo. BFINT is a /POST1 command, so the model must be solved and a .rth file must be available.
An alternative method to interpolate data between models is using the mapping option of the *MOPER command. Mapping is done using four arrays and the “*MOPER,parR,par1,MAP” option. The required arrays are:
1.three-column array that stores the coordinates of the input data.
2.array that stores the data (e.g., temperature) that corresponds to the coordinates stored in the first array.
3.three-column array that stores the designation coordinates for the interpolated data.
4.array where the “*MOPER, parR, par1, MAP” command writes the interpolated data.
